  • 8.1K Views
Fighter posted this 17 December 2022
For God's sake....
I said try the online calculator and you will see the results are the same with Jagau's calculation method !
I don't care about your conclusion, that calculator will show you the right conclusion !
Shelfordella posted this 18 December 2022
This one?
https://www.daycounter.com/Calculators/Inductor-Current-Power-Calculator.phtml
Why should one use the rms current of 0.292a for Isat? Isat should be an instanteneous current, not an rms average. Try 1.09A.
The other calulator only calculates for square wave signals without an I-L current ramp.
Fighter posted this 18 December 2022
the other one from vishay's site. we have rectangle pulses as input in our devices. that's our only input energy.
