Simplicity and power of ether
  • 9.5K Views
  • Last Post 4 weeks ago
Jagau posted this 08 March 2026
 This Polish man named Pachuka does incredible things. Watch this video carefully.
He excites the ether with a 9VDC battery and then disconnects it; the circuit becomes self-sufficient, with the ether supplying the voltage to the lamp.
Jagau posted this 29 March 2026
I am sharing with you these important words from Pachuka for coil construction.
The key point of the circuit is that the installation uses two sources of oscillation and a frequency beat, operating at close but not identical frequencies. When they interact, an effect occurs, called a beat. A lower envelope frequency appears, but it still carries the energy of the two initial oscillations. From the perspective of the etheric model, this can be written as follows: one frequency rotates the medium, the second breaks the symmetry, and their interaction creates areas of increased movement.
It is in these areas that the maximum release of energy and the formation of a directed flow occur. When the beats are established, the ether no longer simply oscillates; it begins to move, redistribute itself, and form a flow. And here's the important point: this flow is not chaotic; it is directed by the structure of the field, which is determined by the system of coils. The role of the coils is that of an interface.
The coils on the right are not simple inductors, but rather an interface between the ether and the electrical circuit. They are tuned, one to a quarter wavelength, the other to a half wavelength. This tuning creates a phase shift, an asymmetry, and the conditions for energy extraction. Figuratively speaking, the coils act as receivers within the ether flow.
A current appears when the ether passes through the area of ​​the coils; the field changes, inducing a voltage and the movement of charges.
Jagau posted this 19 April 2026
update;
The Kacher circuit that powers an accelerator coil L4 behaves strangely with the environment. With an AV plug, it increases the voltage by about a factor of 10, so Pachuka is right to call it that. The operating frequency is 8 MHz. Resonance adjustments on the L3 coil with C2 allow for this rapid increase.
Power input is 12vdc at 41ma for 0.5 watt input for my circuit i made, output circuit is not finish.
Here are the components I will identify in order to understand.
Jagau posted this 21 April 2026
 Some important construction notes.
The left-hand side, L1, L2, L3 of the upper diagram, determines the frequency, phase structure of the pulses, and shape of the disturbance introduced into the ether. Its role is neither to transmit power in the conventional sense, nor to directly supply energy to the right-hand side. This unit serves as the initiator of the process.
The central coil L4, positioned horizontally, is the accelerating coil and constitutes the key element of the entire system. This coil does not so much accumulate energy as create a directional gradient of etheric density. This coil is a phase-shifting element that introduces a 90° phase shift in the propagating electromagnetic wavefront. This increases the voltage amplitude and accelerates energy transfer, which, in practice, allows the output power to be at least doubled without a proportional increase in input energy.
The right-hand side, receiving coils L5, L6, L7, essentially constitute an interface between the tendency of the medium to collapse and the electrical charge.
 According to the model, the ether reacts weakly to sinusoidal and slowly varying fields, but is extremely sensitive to abrupt gradients, and the role of phase relationships is particularly important.
The tunnel effect produces an energy vortex (tunnel effect) that generally does not exceed the spacing between the recycling coils and is approximately equal to four times the height of the energy collection coil. After exciting the ether, when it returns to its initial state it releases energy which increases the output, hence the surplus energy.
Jagau posted this 23 April 2026
First, it's important to produce a standing wave in the Tx coil the one at left in L2, by pulsing L1 at Fr
Its visual presence can be verified using either an LED or a neon bulb.
Since we must work at a quarter wavelength of the resonant frequency, we will have a nodal point (0 volt) full magnetic H at the bottom of the coil and an antinode (full voltage) 0 H at the top.
On Gorchilin website, he made into an image that was easy to understand.
A short video to visualize the quarter-wave standing wave,
note than the two neon bulb are connected just on one wire and LED is on a AV plug. One a the top and the other in my hand to detect standing wave.
Kacher circuit at left and L1 pulsing L2 coil. Operating frequency at 3.3 mhz on TINY-Spectrum Analyser with probe aroud L1 coil.
Jagau posted this 24 April 2026
For those who want to replicate it:
L1 CCW 110mm 4 turns of 0.4 x 4 twisted tegether, L2 CW 70mm  81 turns gauge 24
very simple scematic here:
The circuit is oscillates by itself at the resonant frequency, nothing needs adjusting. The bd911 is not mandatory; I use a BD139 or any other power NPN
For R1 and R2 i use 2 x 50K pot and adjust to 22k and 27K as per upper circuit.
Each coil has its own resonant frequency which you can check by placing an oscilloscope probe next to the coil without connecting it to it; it is very important to place it at a certain distance so as not to influence its own frequency.
If your circuit is not oscillating, change the polarity of the connection of L1 or add a capacitor to L2 on top, like a metal lid from a jug.
worldcup posted this 24 April 2026
The circuit is self-maintaining at the resonant frequency, nothing needs adjusting. The bd911 is not mandatory; I use a BD139 or any other power NPN
Very interesting and nice efforts, Thanks.
Pardon me: Is this self looping (once kick started with 12V battery, it will run forever!) ?
How much output !
Yes, the circuit oscillates on its own; I should have written, as long as the battery supplies the required power.
The goal was to demonstrate the presence of the standing wave. The output will be calculated in the receiving coil. This circuit excites the ether, which produces radiant energy.
baerndorfer posted this 24 April 2026
these kind of circuits run on reacctive energy whicch the rc-source still can supply. i wonder what happen with the energy which you do not capture when transistor switches off. i think the energy went directly back to source. so placing a capacitor which is able to capture voltage spikes should be in parallel to source. but i'm sure you left thouse things out so people get a better understanding in first place.
always a pleasure to read your statements
PS: i'm still guessing because i have not build this circuit. but it is on my list
Yes, that's right, Bearndorfer.
It took me a little while to understand this circuit; I've only just started to implement and study it. It seems so simple, yet its complexity intrigues me.
As you guessed, it's coil L3 and cap C2 from Pachuka's original schematic, shown above, that does this work.
I'll talk about it in another post when the receiving coils are to my liking.
Thanks for the encouragement.
free4all posted this 25 April 2026
Have you tried tying the output (maybe via a stepdown transformer) back into the input (creating a feedback circuit).  It might replace the battery if it taps enough of the ambient.
