  • 4.7K Views
  • Last Post 11 July 2023
Hiall
editor posted this 29 April 2023
Hi Jagau!
Sorry to post in your thread, I just manage to wind 10m of litz wire 0.3mm today.
Jagau posted this 30 April 2023
Good work Editor,
Trying to roll the inductance tighter is better.
For this coil between 690uh and 730 uh it works well, for the 9 turns over the center same thing thighter is better.
YoElMiCrO posted this 30 April 2023
First...
Sorry for not being able to be active.
Some time ago I tested this technology,
I think it's a real test of over-unity.
The problem lies in the amount of noise it generates to your
around, just that, if a way was found to limit it.
so that it complies with FCC rules would be a
good candidate.
SEC Folder.
Fighter posted this 30 April 2023
Hi Yoel,
No worries, we post when we find time to experiment. For example right now I'm putting back on my experiments table the ZPM, as I'll be able to find some time I'll continue the experiments with it in parallel with other experiments. šŸ™‚
The FCC rules are not important, we're here to experiment and discover principles to build this kind of devices.
And they work by perturbing the zero-point field and gathering energy from it so it's normal to generate noise.
I see the coils having 90 degrees orientations in 3D space as Jagau shown to us.
Could you give more details about the schema/components and how the coils are built ?
When you have some time, thanks !
I'm asking because a replication of this kind of device is also on my to-do list and as you can see here I'm not the only one having it on the list.
Interesting Yoelmicro, I see you have already tried some Dr Stiffler circuits like the one you show in series 18 with tuning Led for NILS . This series does not use a signal generator only an NPN Mpsa06 transistor with a frequency beat between 3 coils plus capacitor (modified colpitts), it is the second phase that will be studied.
Yes you are right for the FCC the equivalent in Canada is the CRTC is also very strict. The Doc asked his replicators not to exceed 2 watts in order to prove the effect and subsequently improved the system and well isolated the noise caused by the device when it is at powers higher than 2 watts.
I hold some radio communication licenses and when I maintain power transmitters I see all the work that has been done by engineers to avoid noise that could be caused to the environment, so when the device with a permitted power (Max 2 W) will have been confirmed the insulation will follow with your help and those who want to help
Jagau posted this 01 May 2023
For those who might be afraid of electromagnetic radiation the Doc recommended placing the device under test in a Farady cage, here is what he said:
The radiation around an exciter is fairly uniform at a specific distance, at which point it drops much faster than the inverse square law. In practice a basic experimental SEC will, when operated at less than 24V, emit a field which will cause interference up to 20m, but this depends on the setting and can be as low as 6m. When I say a standard 15-3, I mean one that has an input of less than 1.5W.
SEC exciters can be placed in shields (similar to Faraday cages) and the radiation in the environment is about equal to that of a Dell desktop computer.
Fighter posted this 03 May 2023
Sorry for being less active these days, I have some work to finish at job.
I think I can use for checking the electromagnetic radiation the tester I've built for the Aharonov-Bohm experiment here.
For shielding I've bought some time ago for the water-based device some copper mesh like this:
https://www.amazon.co.uk/gp/product/B08HXXP47R/?th=1
I guess I can use it with a connection to ground for shielding if necessary, I'm not sure if a shielding like this would affect the device. I'll see, for now I need to find some time to build the device.
Jagau posted this 05 May 2023
A very simple Faraday cage  that Doc construct to show effect.
Can be see here:
Jagau posted this 11 May 2023
Dr. H. Aspen was another pioneer of vacuum energy, he said at one of his lectures in Germany:
Scientists do not recognize vacuum as a source of energy. They tell us that a vacuum is, in simple terms, a mere 'nothing', yet they teach with reference to textbooks which state that a vacuum has a permeability 410 exp -7 henries by 0.1 meter and  permittivity of 8.854187817x10 farads per meter.
How can we say that the void, as a medium devoid of matter, has such curious properties if it is nothing?
Permittivity tells us how much energy we can store between two plates in vacuum, when the voltage is removed the voltage is released by the vacuum which the permittivity governs. Dr Stiffler understood that.
Jagau posted this 13 May 2023
One thing that is common in Doc's experiments is the famous avramenko plug experiment.
It is important to understand how this experience works and how close it is to energetic coherence.
My personal experiments demonstrates a gradual increase in the voltages harvested when various capacitive loads such as aluminum plates or different lengths of wires are added to the plug on the negative side, this indicates the capacitive nature of the single wire electrical circuit.
Experiments are underway to demonstrate this fact.
