What we know exactly about Don Smith Device
  • 5.2K Views
  • Last Post 4 weeks ago
HansKammler posted this 26 September 2025
Hello Community,
Since years a lot of people try to replicate the don smith earth system without luck as I see. So I just want to ask what exactly we know about the machine ? I will concentrated on that what I can see in the original Materials. the Raw input so to speak...
There is a schematic on the net which should be "the device". later I found out there are 2 different circulating. It seems it comes from a patent application but i cant find the patent granted.
So on the Image above I cannot see a L3 output Coil ? inside the tube ? where are the wires for L3 then?
since they differ so much (L3 / Parts omitted...) I don´t upload the various ones . this seems to be misleading to understanding as someone has edited them for confusion.
in one of the Lectures he stated , that parts are missed from disclosure because of investors interests and his security.... but it should be easy to figure out for an HAM operator. Ok. My ham operator told me he don´t know..."
there is a lecture where he Lit 1000 W of indecant Lamps on a Board, while his Demonstrator sits left side from the board...But I don´t know if this was powered from this board or a suitcase.
how big is this MONSTER:
for my it looks like a demonstrator only to look - not the device which powered the light bank ?
what you are thinking ?
I didn´t found ANY good Image of this UNIT on the net ! nowhere.
As I found Dons Website in archive.org , every backup has the big Image of this REMOVED !!
no joke ! all his images are since the 90ties here in archive. Not this unit ! damn
OK What we learn: NST , OILCAP, Primary LC (yellow big CAP) - and white shimmering WHAT ?
where is the battery here ? No powersupply ? Why ?
Why the white core goes away from panel ?
is there a Barker coil in front of device on the Floor ? with 8KV yes ? I cannot believe this.
this we all know Ok...
and the people try to draw schematics from that what they see. I found in the office video exact the device which was used back then:
(in the upper left part)
and lower side: the HIGH Power DSE V3
On inventors Weekend Don told us, that the Amcore transformer is exactly the device he showed 1996 in the suitcase ! But this is a completely different device than the Earth system he showed 1996 in my opinion.
So what we exactly know for sure about this device ?
The NST is a short Circuit ! No Sparkgap, no charge Capacitor -> OK
then:
if you put in on the same speakerwire (L1 which goes arround the AMC) and create a short ! VERY BAD ! Don´t do that !! you kill the NST in seconds.
OR: if you use it Bifiar as we can see -> you supply the 2 wires with HV one next to the other
AND LET THE ENDS OPEN. If my theory is right you have a cap coupling in the other coils (E Field)
but this is theory and I was not able to confirm on testbench at the moment.
Found another image:
How are the coils winded ?
Could you see how the wires are going from and to ?
my friends told me the could see its POC style. But I´m not sure. and IF yes . which one ?
l1 to L2
or L1A to L1B to L2
or L2A to L2B to L1 ? Crazy...
I hope this is not boring ? sometimes its good to brainstorm and check the way we are of...
some Images from my archive:
the cap should go between L2A and L2B on the middle TAB and goes to Earth . This should do a DAM for the ground electrons. Because the resistance is High for the rotating electrons in the L2A/B Reactor.
But this system needs then a third coil (L3) loose coupled (to not affect the NST Supply)  to pull the electrons out of the Tank for using with Capbank / Loads
Inductive power out with diodebridge under metal and smoothing caps in parallel.
Coke Machine Japan. Power inverter pcb. seems to be out of the box. not self builded. whats next to it on the table ? the rest of the ambient device ?
Jagau posted this 24 December 2025
Okay, very well, let's start from the beginning to make sure we understand each other.
Let's look at the diagram you provided here.
It seems you're operating at a certain voltage, (1) 98 volts, as mentioned in one of your posts or correct me. L1, L2, L3, L4 is your (3), which appears to be several coils connected in series.
We can't see your switching system to L1 . And (4) is probably a square wave pulse, or I don't know what it's doing there.
Let's start with that, i am interested to understand. You will make the following later from (5) and (6)
Another question: you declare.
even at 45khz, a capacitor of 10 Farad would charge up in a twinkle of a millisecond over and over again.
Could you please tell me the operating voltage of your 10 Farad capacitor?
Darediamond posted this 26 December 2025
If you want to keep figuring out, that is fine. I have given a simple instruction to be followed over any further explanations about the revealed Circuit and you know it.
  • worldcup
Jagau posted this 26 December 2025
Darediamond,
I asked a very simple question, which you refuse to answer here for everyone's benefit.
You are insistingt ocontact you on another private site? This demonstrates your intentions.
I personally advise everyone against falling victim to this type of scam.
Answer this simple question:
Why are you asking people to contact you privately on WhatsApp?
ROmanian posted this 26 December 2025
Hello @Jagau.
Because he does not intend to share with the community — that is, if he even has something to share.
The goal of this forum and its members is to share open‑source work so that everybody can benefit. This is not in resonance with the goals of the member @darediamond.
He will make noise over and over again, and in the end he will get banned.
Just my 2 cents.
andy2 posted this 26 December 2025
@Darediamond
what is correct purpose of the resistor #6 ? lower current going to #7 to draw less from source or to affect resonance somehow ?
Fighter posted this 26 December 2025
My friend,
The reason is he got nothing and knows nothing, he is just a scammer.
More in my OSINT research about him in this thread.
Sorry about this, I needed some time to find who this guy is, I don't want to risk to be unfair and ban genuine researchers.
Quoting:ROmanian
Just my 2 cents.
Well, I guess you won this bet faster than you expected. 😄
He was already under investigation...
HansKammler posted this 31 May 2026
Replying To: magluvin
he have to send the hv to the open ended litz wire. If you close it you kill the neon transformer with short circuit. He use the e field changing as drive the pri coil of the metglas trafo
Unimmortal posted this 4 weeks ago
Ok, I'm going to say something that might be contentious. Don Smith said 'make it look pretty', he implied 'don't show everything'...
The high voltage high frequency way he created a disturbance in the local environment is fairly well understood, sine waves + diodes = square waves.
The 'output' bucking coils or counterwound coils placed over the top are used to differentiate that initial disturbance. Problem here, you can't take an output from the very thing that helps create the condition.
I strongly believe the missing piece he has omitted or misplaced, is the output coil itself!!! That needs to go over the bucking coils to pick up the differentiated environmental field the the pulse/square wave coil initiates.
Now a load will create an opposing magnetic field (causing Lenz to materialise), this 'load' field can then be tuned by adjusting placement along the bucking coils to enhance energy output.
The same would apply to a magnet rotor and coil arrangement, whereby the magnet will induce N and S (coming and going) that the bucking coils attempt to reconcile. An output coil over the top will then extract energy without the tax, because the tax is eliminated if the load field contributes to the bucking coils bucking.
So the trick might be to work backwards and start with the load that will create a field.
