Aether Engineering - Displacement Currents
  • 927 Views
  • Last Post 01 July 2023
Fighter posted this 24 November 2022
I'm adding here for later references two videos made by Master Ivo about how to produce displacement currents.
Master Ivo is an zero-point energy researcher, his research is open-source and he is using in his research mostly pancake coils but what he is talking about in these two videos are applicable to any kind of coils.
Use this for inspiration in our research.
Now we all know the time will come when the crazy-boy from the old aboveunity site will claim that Master Ivo also copied from him, have no doubts about that ! After all, the ZPM's asymetric coils, Mater Ivo's pancake coils, Graham Gunderson's coils... what the hell - all kind of coils are copied from "his" so-called partnered output coils (the ones he actually copied from one of Don Smith's devices), isn't ?.. šŸ˜„
Fighter posted this 01 July 2023
Seems our friend Master Ivo is traveling with us on a parallel road but to the same direction: Rome.
He's using different methods (pancake coils, no core) but the principle is the same:
He is using identical pancake coils but he discovered that if he makes them asymmetric/inequal by placing different capacitors in parallel with them a high negative pulse is generated which will be compensated by extra-energy coming from the ground connection. The environment will always provide energy when there is a energy gap (the high negative pulse):
See ZPM's asymmetric/inequal coils and the high negative pulse from the well-known waveform:
What do we see here ?
  1. After a short period of charging the coils (we have 30% duty-cycle here) the MOSFET is turned off;
  2. A dramatic collapse of magnetic fields causes a -144V negative pulse;
  3. We see immediately energy coming for compensation and the voltage raises back to 3.62V;
  4. The voltage decrease very slowly until the MOSFET is turned on again for the next charge cycle.
Remember at points 3 and 4 there is a long period where the MOSFET is still off until it's turned on again.
So where is that energy coming from ? Certainly not from the DC source as the MOSFET is still off.
The environment is compensating the imbalance because the zero-point field doesn't like imbalance and it's always providing energy to compensate it.
Just like Master Ivo discovered in his experiment above, when his device is producing a high negative pulse there is a high current coming from the ground into the system to compensate and balance the system again.
The source of the incoming energy is not important (ground or air), the zero-point field is everywhere and the principle is the same.
Just like in Don Smith's devices when he explains that the "grounding" could be the ground or air and he call it "the source of electrons".
Just like in Atti's ZPM replication which is not using a ground connection but he says "Grounding can help...".
Just like in my ZPM or in Graham Gunderson's device where we see almost identical waveforms and the same principle in action:
So the principle is the same and Master Ivo is traveling with us on our way to Rome.
Doesn't matter if he is using different coils (pancake coils) and because he doesn't use a core he needs to put those coils together to couple them and make them work at the same resonant frequency. Also doesn't matter if his coils are identical so he needs to put different capacitors in parallel on them to make them asymmetric like ZPM's coils.
The principle is the same and the result is the same: extra-energy coming from the environment to compensate the imbalance produced by the high negative pulse.
