Kapanadze/Akula device replication from Azerbaijan
  • 952 Views
  • Last Post 31 January 2023
Fighter posted this 21 January 2023
Hello friends,
You know Mitza84 from our secondary/backup forum, even if he is not active here we have a small Romanian Facebook group where we are admins and where people (mostly Romanians) are exchanging free-energy related data.
One day ago Mitza84 shared a archive containing conversations, schemas, details and explanations related to a succesful Kapanadze/Akula replication. The data is coming directly from the author of the replication named Ruslan Gadzhiomarov from Azerbaijan:
The device was presented in 2021 in a public demonstration.
The YouTube video of the demonstration is here:
Just in case the video will disappear from YouTube, I've uploaded a copy of it here on our site:
Here are just two samples from the explanations received from the author through a forum:
...And in direct discussions:
It's too much information about the device to show it directly in this post so I'm attaching an archive with all the information received from Mitza84.
In the archive you'll find the original documents in Russian language, photos, schemas, explanations and some of the translations in English using Google Translate so be aware the translations could not be 100% accurate. There are still documents and notes on the schemas in Russian language for which you'll need to use Google Translate in order to understand what they author is saying there.
I'm sure our friend Vidura will find all this information very insightful as the device is similar to the project he is currently working on.
It also should be very interesting for our entire team as author's explanations are refering to principles and functionalities which are employed in all types of devices not only to Kapanadze/Akula devices.
Hello friends,
And some updated information.
On one of the the forums the author said the previous schematic is almost corect except for the connection from the copper pipe to the bridge diode rectifier and provided a second corrected schematic (see https://energyscience.ru/topic518-42.html):
These are the forums where the author is active:
https://realstrannik.com/forum/hitachi/1848-ruslan-gadzhiomarov?start=10
User: Cing-86jt
User: Cing-86
You gonna need Google Translator to check the posts on these forums.
On both forums the author seems disapointed by the rude reactions of the people there...
Seems it's a very familiar situation we all get used to, isn't ?... 😉
Fighter posted this 22 January 2023
And another video with the device shown by Ruslan Gadzhiomarov:
Mitza84 posted this 29 January 2023
Ok guys hello again the inventor give this file as a first part of the device to get familiar with it  .so he say the voltage we get it from the push pull and the current (amps) from the high voltage part wich can be kacher or flyback of 5000volts      this device autor say it output 500w
but with the help of the grounding of course so the pull inverter have a coil wich is in series with a capacitor of microfarads valuea from 2uf to 25uf depends of the coils and goes to the main coil to help build voltage plus amperage i have a schematic for the device from the forum but i can not guarante that is 100 percent acurate because is from a user not the autor and i dont know if he got it from the inventor directly or not . but we have enough detailes to buyld the device .i will try to help as much as posible but the best is if you make a little time to read the litterature that we have on the device because i think is gold information he say about akula and ruslan kulabuhov that they have fakes and the basic he got it from an exsisting patent . wich is here   and translate in english the page and you will see         https://studfile.net/preview/8198608/
diagram from the chat above
i will give some youtube links to watch wich are connected to the first part of the device  ,these russian guys have ondoing experiments regarding this device   so it easyer to see progres on others and than we can continue from there .they have more interesting videos on this topic so watch please
Fighter posted this 29 January 2023
Hello again Mitza84 and welcome to our new home.
I added to the thread all the information posted by you at that time.
Anything you have to add, please feel free to do it.
About the device, Vidura is experimenting with something similar in the BTG research thread and he is well advanced in this direction so I guess his insights could be very useful here.
  • Gandalf
