The Don Smith Effect
  • 42K Views
  • Last Post 08 October 2026
Fighter posted this 27 March 2024
Yeah, it appeared on "radar", I can track it here.
Fighter posted this 02 April 2024
The disks arrived in Europe and seems they're going through customs, should arrive soon:
https://track24.net/?code=158271900288259564003272
Fighter posted this 06 April 2024
Seems I was too optimistic. Usually after leaving the customs the shipments arrive in 1-2 days.
I hoped I'll have the disks before the weekend but I'll need to wait for the next week.
What's curious is the tracking shows unsuccessful delivery attempt but nobody tried to deliver anything.
No phone call or doorbell ringing from the courier.
I'll see how it goes on Monday, if necessary I'll contact the delivery company to ask what's going on.
Fighter posted this 08 April 2024
 I contacted the courier company and they said I will receive the discs shipment today.
Fighter posted this 09 April 2024
Yesterday I received the discs (I put them in two bags I have from TME):
Now I need to start building the customized capacitor.
I was thinking a lot and I still didn't came with a solution to make this capacitor variable. And from the experiments the capacity of the capacitor is important regarding the effciency of the energy extraction process.
Also I need to think how I will solder wires to the discs without introducing wires between them so they stay as close as possible to each other.
So yeah, building this customized capacitor have some technical challenges and I'm not sure I will be able to make it variable.
I'll see.
I'll come with updates.
Vidura posted this 09 April 2024
Good experiments Fighter! I will need some time to recap the updates on the forum!👌
Fighter posted this 10 April 2024
Thank you Vidura !
Yes, this is something what Don Smith told us about and even shown it in one of his public demonstrations but no one gave too much attention or realized the signifiance of it.
This is energy we can get without affecting the input, a practical way to apply the "Don't kill the dipole" principle as Tom Bearden put it.
I know, it's a lot of new information to process, take your time. 🙂
Fighter posted this 04 May 2024
And some updates here.
Yesterday I received a 4 mm diameter carbon fiber tube and 50 mm width Teflon band:
I ordered them during the previous week from here and here.
The carbon fiber tube is necessary so it doesn't bend when I'll fix so many metal disks on it (any plastic tube would bend).
The Teflon band is for separating electrically the copper and aluminum disks. The Teflon is well known for its excellent dielectric properties, that's why I choose it for building the customized capacitor.
I was thinking a lot and I don't think there is a way to make the customized capacitor variable. I would need a mechanism to modify the distances between the plates while keeping those distances equal to each other. Very hard to build such a mechanism and fit it inside the DSE coils.
But as I shown during the experiments the capacity of the variable capacitors is important in the effciency of the energy extraction process.
So before building the capacitor I need to experiment with let's say 5 copper disks and 5 aluminum disks in two configurations as in the image below:
One configuration would be like the one on the left side where the extraction blocks (one block having one copper disk, one teflon disk, one aluminum disk and again one teflon disk) will be placed close to each other.
The other configuration will be like the one on the right side where the extraction blocks (one block having one copper disk, one teflon disk, one aluminum disk and again one teflon disk) will have distances between them (I will try different distances modifying them manually).
What I want to check is if there is any degradation in the energy extraction process if there are no spaces between the extraction blocks (like the configuration on the left side).
Based on the result of the tests I'll need to build the customized capacitor like in one of these two configurations. Hopefully the left configuration will work as it will be much easier to build the capacitor that way.
Another delicate work will be to connect a common wire to each copper disk and another common wire to each aluminum disk for energy extraction. I'll need to solder those wires on the edges of the disks, I cannot solder the wires on the sufaces of the disks as that would introduce distances between disks and that would modify the capacity of the customized capacitor.
A lot of checks to do and things to verify before starting to build this customized capacitor.
Note: I also need to resume the work and to finish the presentation video for YouTube with details and results of the latest much more efficient DSE configuration which I already presented to you guys here in this post.
Jagau posted this 04 May 2024
How to make HV variable air capacitor with copper plate?
Thanks Jagau but unfortunately the mechanism for making it variable would be too big to fit inside the coils...
