Aharonov-Bohm effect as zero-point energy concentrator
  • 1.4K Views
  • Last Post 07 February 2023
Fighter posted this 23 May 2022
This is the imported thread (from the old aboveunity site) about my experiment investigating the Aharonov-Bohm effect as zero-point energy concentrator:
UndisclosedMember posted this 16 July 2020
Hey Fighter really good idea the tool you made!
Thank you for sharing it!
Fighter posted this 17 July 2020
Thank you UndisclosedMember, please feel free to use the idea if you find this tool useful for you. It's simple but very effective.
Fighter posted this 31 July 2020
Sorry, I didn't progressed too much with this experiment, I dismantled the coils (because they were too strong for this core) but I didn't found time to build new coils. I allocated some time to my secondary project : GLED.
Fighter posted this 02 September 2021
I forgot to post the video with my experiment in this thread, sorry, I'm adding it here now:
  • Atti
UndisclosedMember posted this 05 September 2021
Hello fighter
could show me with a drawing how to make this little tester?
thank you
Fighter posted this 05 September 2021
Hello UndisclosedMember,
Sure, this is the schema of the tester:
The details can be found on my post above made on 16th July 2020.
For the coil I used 0.2 mm copper wire but I didn't counted the number of turns, I just used some wire left from other experiments.
Looking at the photo I took at that time could be a few hundreds of turns I guess (link to larger image here):
The "normal LED" (red color) is an 12V LED, the other two LEDs (while color) are more sensitive (I suppose they have very low voltage) and I took them from some Chinese lighters like this (link to larger image here):
And this is a photo of how the LEDs are connected inside the tester (in parallel) just the top white LED which indicates BEMF have inverted polarity than the other two LEDs (link to larger image here):
Before soldering the LEDs to the coil output you must test their polarity to make sure they are indicating correctly, meaning the top white LED is indicating BEMF (magnetic south pole) even if it's weak and the other two LEDs below it (red and white) are indicating EMF (magnetic north pole). The 12V red LED is actually indicating how powerful the pulsing N field is while the white LED below indicates just the presence of the pulsing N field even if it's weak. If it's a weak pulsing N field the red LED's light is weak too or even off.
I've made this process using the ZPM, knowing that on top of ZPM are two pulsing and opposing magnetic N fields and at the bottom of the ZPM are two pulsing and magnetic opposing S fields.
This is the description of the tool, if I didn't explained too well something please feel free to ask and I'll answer to your questions.
Fighter posted this 24 May 2022
Thread import is complete, it will be continued from here.
Atti posted this 27 May 2022
Again, I took out the old hypersilicon transformer layout.
There is no permanent magnet right now. (otherwise it doesn't change anything)
Since the metal oxide varistor has a capacitive character, I loaded the output coils with a capacitor.
Yes, it’s such a barren performance, but now I’m specifically focusing on it.
I was wondering to what extent the current was charging back to the power supply.
How the voltage of the drive coils changes.
How the shape of the current changes.
How voltage and current change together.
As well as the extent to which the oscilloscope figures show similarities to those given by Naudin and Bearden, respectively.
As expected, the output coil affects the input coil. This is not necessarily a bad thing.
But as a result, recharging may appear on the power supply.
Energy reflection is not what we have seen so far. So recharging doesn’t occur to such an extent. But that's a different layout.
Separation of magnetic fields cannot be achieved with this arrangement. (as reactive power is seen in video or other layouts)
Some snapshots of the layout.
First measurement is not a measurement. Second measurement half measurement. Third measurement is a measurement.
Fighter posted this 27 May 2022
Hi Atti,
The Aharonov-Bohm effect could not manifest itself if there is no permanent magnet.
A quote from my first post on this thread (based on what Tom Bearden said):
2. Seems that when a permanent magnet is placed inside of the core without gap so the entire magnetic flux of the permanent magnet is "sucked" inside of the core and become trapped there are two effects:
  • the permanent magnet become almost inert so it stops emitting magnetic field around it or (depending of how close to 0 mm is the gap between it and the core) it's emitting a very small magnetic field compared to its original magnetic field;
  • when the previous conditions are happening and almost all the magnetic field of the permanent magnet is trapped inside the core something new happens: outside of the core a zero-point/quantum/aether (however you call it) field is formed containing additional energy ready to be captured by our device.
3. The practical way of capturing additional energy from that new zero-point/quantum/aether field formed outside of the core is to "shake" that field by pulsing the small command coils on top of the MEG. That will make the output coils capture the additional energy contained in that field therefore zero-point energy is added to the device's output.
Dear FIGHTER!
Please DO NOT misunderstand, just think.
I don’t want to mislead anyone with my train of thought. So if you think so delete this post!
But let's have a few comments!
-I don't believe in exotic formulations. No voodoo.
-A very many people have failed to reproduce the equipment by ACCURATE information. T.Bearden or J.L. Copied by Naudin, so literally without thinking.
-Why could not many hundreds or even many thousands of experiments reproduce the given parameters?
-What are the parameters?
-What is the load parameter? So how can this be utilized in a HOUSEHOLD?
-Obviously we want to use the extra energy, but what makes the extra energy?
-Or what makes a piece of equipment self-sustaining?
-Have we ever heard that the inventor did not provide proper information?
-Or classified information?
-Or did you even give incorrect information about the entered and ACCURATE measurements? Even intentionally?
Comment from one of the forums:
Hi Leonel!
No the objective was not achieved. The words meant, hmm better not to write something that I will regret. I'm a bit sad since here are 575 members and maybe you can count in two hands successful aboveunity devices with very low output power of course. Well see...
Why don't you dare describe more information?
No.
Not because you did NOT test the SPECIFIC PARAMETERS properly.
What can a simple experimenter do then?
He starts thinking.
Since I do not want to mislead the forum with useless writings, I will omit any comments below.
  • Gandalf
