Natural Resonance Frequency
  • 754 Views
  • Last Post 29 May 2023
Many times we are talking about the resonance frequency when describing our devices.
But do we really understand what natural resonance frequency really means and what advantages it provides to our devices ?
Let's see...
Any object have a natural resonance frequency. When two objects have the same resonance frequency we can see both reacting in the same way when we do a action on one of them.
Let's start with sound resonance frequency:
The input used to produce the sound is the same. But when the frequency of the sound is not matching the resonance frequency of the glass there is no energy produced in the glass so the input energy is wasted.
But when the frequency of the sound is matching the resonance frequency of the glass there is so much energy produced in the glass that it is destroyed.
Notice how the input energy is the same in both situations but the wood stick starts to jump around only at the natural resonance frequency of the glass !
We can see the force applied to the first object is the same every time. But at resonance frequency there is action at distance with no physical contact. Both objects are reacting like both of them are hit !
So we saw what natural sound resonance frequency means for some objects made of glass or metal.
But think what natural magnetic resonance means for the devices we're building and experimenting with !
Everything in our devices have its own natural magnetic resonance. Coils, cores, everything...
You want to know how to use the natural resonance of the coils to multiply the input energy without actually affecting the input or even decresing the input ? Just like I shown in my experiements with ZPM and also our members shown with their ZPM replications ?
Below is a 30 minutes video showing you how to do exactly that. The video on YouTube is here but just to make sure we'll still have it even if it disappears from YouTube I've made a copy of it and I uploaded it on our server.
While you watch it always please keep looking at the power meter showing the energy used for input.
Even if it's a long video I guarantee you gonna learn a lot about the natural frequency of the coils and how we can use it in our devices to our advange and to have multiple output loads without affecting the input or even decreasing the input. You'll not gonna regret any minute spent watching this demonstration:
So, after watching the video, what do you think ? How many loads can we have on output without affecting the input ? ๐Ÿ˜‰
Remember what one of our great teachers, Tom Bearden, told us: "Don't kill the dipole !". Now, after learning all these about the natural resonance frequency, it gives a whole new meaning/understanding to Tom's advice, isn't it ?..
Now we can understand better what's going on in our devices at resonance frequency and how to use it in our experiments !
Edit: I'm adding here a link related to resonance frequency. Sorry, I forgot about it when I created this post:
What is Resonance ? Tesla vs. Steinmetz
Quoting a fragment from the reference link above:
“Standing waves don't form under just any circumstances. They require that energy be fed into a system at an appropriate frequency. That is, when the driving frequency applied to a system equals its natural frequency. This condition is known as resonance. Standing waves are always associated with resonance. Resonance can be identified by a dramatic increase in amplitude of the resultant vibrations.
Let's see...
baerndorfer posted this 28 May 2023
AlteredUnity posted this 28 May 2023
Awesome presentation Fighter, well demonstrated. I have coils for similar configuration, and you can learn so much about resonant conditions. Few things you can do that may improve setup: -Add a ground to one or all of the output coils(floating ground, like metal ball or table, tinfoil, etc) -Run the primary using a gate driver(with this you can watch the current drop as well, though if your primay is in parallel this can cause big issues with current if not in resonance.) โ€If you don't have the primary in series, try that. as well as 1 series cap of same value to the parallel LC primary(Fr will be lower). --for an interesting experiment set the primary in series with cap, where the coil and cap meet connect a single wire to two diodes, anode and cathode of each diode connected to wire. The other end of diodes connected to a high voltage DC capacitor to their respective terminals. Watch the charge that builds on that capacitor, then add a ground(floating or not) to the ล†egative of that capacitor. This will greatly speed up the charging. Later run load through the negative side of capacitor, then to ground.
I'll set configuration back up to make sure it's correct but there is so much people can learn with these type of configurations. It's been a while so I'll try to verify the setups described later.
Thank you for the info baerndorfer, that's seems like the setup I was trying to describe in another post, I'll look further into it with time, have you ever implemented something like that? If so please share some pointers. Thanks.
Fighter posted this 29 May 2023
Hi AlteredUnity,
I can't get credits for the presentation as it's not mine, credits go to the owner of the YouTube channel:
I found the demonstration while searching for additional information about what Don Smith called "The Don Smith Effect" described in his patent NL02000035.
You're right, I also think it's the perfect demonstration on what natural resonance frequency can do and why we use it in our devices. It's a demonstration which even trolls/naysayers can't argue with. ๐Ÿ˜‰
In every device where we see the input remaining constant when loads are added (like Dr. Stiffler's SEC technology Jagau is experimenting with) or the input is decreasing at resonance frequency (like ZPMs) that means this effect is used to go Beyond-Unity.
So I thought the demonstration fits perfectly in this thread I intended to create for some time ago and with the other videos in this thread it helps everyone to see the natural resonance frequency in action and understand better how our devices work and how they are using the natural resonance frequency to get extra-energy from the aether/zero-point field.
Note: at the end of the first post I added a link related to resonance. Sorry, I forgot about it when I created the first post:
AlteredUnity posted this 29 May 2023
Ah, sorry for the confusion, I have 3 coils same configuration, ordered from Rick Friedrich, when searching for a setup like the one Don Smith was inspired by.
Replying To: AlteredUnity
No problem.
Yes, I know Rick Friederich, I'm a subscriber to his YouTube channel.
He is working a lot in promoting and explaining Don Smith's technology.
baerndorfer posted this 29 May 2023
Quoting:AlteredUnity
hi AlteredUnity,
i started my journey on aboveunity and was banned for no reason few weeks ago. i did a lot of experiments on this subject -> here is the link to the diode-plug with some more info. https://aboveunity.com/thread/extracting-energy/
regards,
Inception posted this 29 May 2023
Replying To: AlteredUnity/Fighter
It's time Rick gets some good press. He has spent more effort building working devices and decoding patents in this field than any of his critics. His presentations are candid/verbose; not spared detail, opinion or philosophy. He has amply revealed the works of Benitez (a favorite innovator) and his "Selfish and Unthankful Circuits or Loving and Giving Paths" studies are fascinating.
One of my favorite demonstrations with coils: Harmonic Oscillations
Years ago I purchased one of his universal radiant battery chargers, and though it was relatively expensive, the return on investment outweighed the cost, tenfold. I have recovered countless older lead-acid and NiMH batteries, small to large capacities, also defunct EV batteries.
fyi - Meetings in Europe, 2023:  August 5-6.
Jagau posted this 29 May 2023
Totally agree Inception, Rick is a person who gives a lot of his time and his knowledge. He is an electronics engineer and he knows what he is talking about.
He worked for a long time with John Bedini on the concepts as an assistant and as you say I recognize him as an excellent example for teaching what he knows. I also like Harmonics Oscillation, this is an very good example. The video that Fighter presented to us is also excellent.
