Non Linear Resonance
  • 12K Views
  • Last Post 14 January 2025
Atti posted this 03 November 2020
I have one of the resonance points. The yellow trail is the H bridge control sign. When this resonance point is there there is some recharging to the power supply.
  • Gucio
Jagau posted this 03 November 2020
Hi Atti
You mean that compared to the number of amps at the input you have the same result but the current drops at the input??
  • Gucio
Yes. See the video uploaded to the Vidura thread. History as well.
A video from Don Smith who declares that several components in his system do not need to be there.
Don video; Okay you want to look at it for a couple of minutes here and then we'll start talking about, it there's a number of unnecessary parts there that we're
actually put in there because people expect to see them actually on this you
can take everything back this way and take it off of there and it will work
just fine you can also take the spark gap off of it and it will still work
just fine and the reason for that is that in the coils they have their own
specific resonance due to the fact that they have both capacitance and
inductance and when you cross that on a chart you find that that particular
length of wire will have a specific frequency and it will load and unload by
itself and you don't need spark gaps or you don't need anything else your Tesla
coils.
This is what allowed me to duplicate the voltage at will without affecting the input, as Mr Smith says and it work.
He call this D.S.E. (don smith effect)
  • Gucio
Jagau posted this 21 November 2020
An Answer to America's Energy Deficit - 5th Edition - January 1997.pdf
An old document from Don Smith specifying that:
The electrical circuit equivalent o a bloch wall is a diode.
Very interesting information and many others which do not appear in more recent books
  • Gucio
Fighter posted this 01 December 2020
I have 4 questions about your device:
  • what's the size of the gaps between the coils ? that's important. maybe 1mm ? more ? less ?
  • what's the size of the wire ? I have some 0.4mm wire available here
  • I have an AL 9500 potcore, do you think I should use a lower number of turns ? you use 80-100 turns per coil for your AL 6000 potcore
  • I don't have oil capacitors, so low ESR capacitors are working well with this ? is the effect still present when using them ?
I intend to experiment this with your AC oscillator, to replace the signal generator in the diagram.
Thanks for your advice !
Jagau posted this 01 December 2020
Hi Fighter
  1. Between the coils there is only the thickness of the black electric tape with only one turn this allows the maximum capacity between the coils.
  2. AWG is 24
  3. Mine have Al 7800 with 9800 it will be better. I use exactly 100 turns, which is important for the correct frequency. With 100 yours you will have between 26 and 29 Khz at the resonant frequency.
  4. As Tom Bearden said the more the capacitor has the internal regularity to the deformation the better it works, for LOW ESRs at these voltages there is not much difference. It also works with propylene capacitors.There are two definite advantages to using oil capacitors
  1. As I work in high voltage, it helps prevent arcing from between the two plates.
  2. Better temperature stability so that it works optimally
                  You will have approximately 40 to 60 times the output voltage of what you place at the input
                  Wound first 2 coils CW-CCW and last one CW
                  What people don't realize is that 2 coils on top of each other is like a capacitor, you see the effect depending on the capacity of your set up, I think you must have observed this effect with your Romanian ZPM
                 hope this help
  • Gucio
Jagau posted this 06 December 2020
Just a link test
ABOUT EnerGenius Favorites
You will be able to appreciate this document with many very interesting links
  • Gucio
YoElMiCrO posted this 18 December 2020
@Jagau.
I already have the POT-Cores in hand.
I'm starting the experiments.
Buy 10, they've got 9 whole, all right.
Here's an image.
Thanks you.
Jagau posted this 18 December 2020
Its's look very good Yo
Good experiment and have pleasure with this.
I am experimenting at the moment about two switching mode in different time and phase angle for coils at Zero crossing Switching (ZCD). Commonly called Synchronous switching.
Almost everyone here will be able to take advantage of this as it applies to most of our switching circuits.
I will talk about all this again when my switching circuit is ready and it will not be long. I already have good results.
 have a nice day
  • Gucio
