  • 19K Views
  • Last Post 2 weeks ago
Fighter posted this 16 January 2024
Here is a video about how the ground connection can amplify the energy of a device by being in resonance with Earth:
Jagau posted this 19 January 2024
Hi Fighter
In a video from 1994 we can clearly see Don Smith explaining to a group how to pulse the two coils in opposite phase series and harvest them on a single coil, which is the correct method used
Watch the momentum grow with each step
Most do it in reverse which leads to no results, he himself says that not many researchers have succeeded in doing it, only a few have listened.
Good way to pulse the coils. The most important thing is the mass gate between the two coils.
Fighter posted this 19 January 2024
Yes, I know the 1994 video and this configuration will be one of my many experiments with Don Smith's tech.
But in this first experiment I've done the two coils are not opposing but forming a biggher coil and I confirmed the part with capacitor plates perpendicular on that coil (inside of it) extracting energy without input increasing.
I'll come with the video of this first experiment and you'll see I'm using also single-wire output from the capacitor plates.
Sorry it takes so long to finish adding all the necessary info and schemas in the video of this experiment but it's a very time-consuming process requiring attention to details and I worked on this when I had time:
Hopefully I'll finish it and post it here in the weekend.
Jagau posted this 23 January 2024
Hi Fighter
Indicators of the standing wave in the coil inductance for your project.
Easy to do for ¼, 1/2, 3/4 and one wavelength and more here;
https://gorchilin.com/articles/coil/indicator?lang=en
Fighter posted this 28 January 2024
Okay, I just finished cleaning up the recent "noise" we got yesterday on my threads.
About the video of my first experiment, the plan of finishing adding information to it in the last weekend didn't worked so I did it using chunks of available time during this week. I underestimated the required work for doing this, it took almost 10-12 total hours. As I wanted it to be on my YouTube channel, I tried to add as much as possible information in the video so viewers on YouTube which probably don't know all the information present in this thread to understand the equipment I used for this experiment and to understand the effect I'm demonstrating. Hopefully I succeeded in making everything clear... šŸ™‚
So this first experiment is successful and it's demonstrating this first effect I was talking about here:
allows magnetic waves to change back into useful electrical (coulombs) energy. Magnetic waves passing through the capacitor plates do not degrade and the full impact of the available energy is accessed. One, or as many sets of capacitor plates as is desired, may be used. Each set makes an exact copy of the full force and effect of the energy present in the magnetic waves. The originating source is not depleted of degraded as is common in conventional transformers.
So here is the video:
A few words about this experiment.
Keep in mind that in this experiment we're extracting just a tiny amount from the energy available for extracting.
The plates of the variable capacitor are occupying just about  1/10 from the total length of the big coil and are extracting the energy just from that area. From that small area we're extracting pulses of 22mA (the consumption of the LEDs) while the input is not affected and remains constant in the range of approximatively 65-75mA. Much more energy can be extracted by using more capacitor plates placed inside the big coil on its entire length, possibly more energy than we're using on input. Do the math...
The measurement module is not showing fixed readings of the input, it's varying in certain small ranges but those ranges are not changing when we don't extract energy or when we don't extract energy. The readings are good enough to demonstrate the effect: input is not increasing when we extract energy, the input is "blind" and not affected by the process.
I'll think of ways to make the measurement module's readings to be less variable, maybe a big capacitor after the measurement module will help in supporting the variable/pulsed consumption of the device. I'll see.
In order to keep the input "blind", unaware of the energy extraction process, I used one single-wire for transfering the energy to  the load and another Earth/Air wire connected to the load. This way we apply the "Don't kill the dipole !" advice Tom Bearden told us about.
As I specified before, I'm trying to avoid life-threatening high-voltages they are risky and my equipment is not capable of handling kilovolts. So I'll keep the voltages high enough to be able to demonstrate the effects but low enough to not be life-threatening and to not destroy my equipments. Therefore in these experiments I will not see high energy gains as we saw in Don Smith's devices but high energy gains are not the scope of my experiments, the scope is to demonstrate Don Smith's tech.
I know Don Smith told us about a variable resistor/capacitor placed on the Earth/Air gounding wire and adjusted until that resistor/capacitor becomes "a dam of electrons". I didn't experimented with this yet but will be a part of the incoming experiments.
So I'll keep experimenting with the current configuration and with this effect for a while, looking for improvments before jumping to the next experiment which will try to study this (as we see it in Don Smith's presentations):
But until the next experiment there is still a lot to explore in the current configuration and finding ways to improve its efficiency (including the variable resistor/capacitor on the grounding wire).
I'll come with updates about it.
@YoElMiCrO, I know I'm late with importing your Ferro-Magnetic Resonance thread from the old site, sorry about that. I'll start working on that.
AlteredUnity posted this 30 January 2024
Very well put together video and experiment Fighter! Have you tried running a load directly from the capacitor(two wires)?
Also have you cheked what you maybe able to get from the one wire using Avramenko plug? I'm curious the effects of running your coils in a series tank circuit, like baerndorfer demonstrated, would have on the plates.
Fighter posted this 31 January 2024
Hi AlteredUnity,
Thank you, I tried to add all the information in the video so is clear for everyone all the steps of the experiment and its purpose. Even if that editing work took a lot of time, more that I initially estimated...
I also tried with the both wires connected to the variable capacitor but the energy extracted was much lower than when using one wire and Earth/Air gounding. But that could be because I didn't used a sheet of copper, a sheet of dielectric and a sheet of aluminum as Don Smith presented in his experiment:
The goal of my experiment was to demonstrate that capacitor plates at right angle to coil are extracting energy without affecting the input and I succeeded in demonstrating that.
I should try with a custom-made capacitor made by multiple sheets as described above but I don't have the materials and I didn't made plans on how to build it yet:
Getting the materials and building this capacitor will take some time but I intend to do it.
About diode plug and capacitor on output, didn't tried yet but I intend to do it. I'm thinking a microwave capacitor as Jagau is using in his experiments would be what I must buy and use for this purpose:
Also I want to try with variable resistor/capacitor placed on the grounding wire ("electrons dam" as Don Smith named it).
And I'm gonna order a new voltage booster which can provide max. 50V (the current one can go to max. 30V): https://www.aliexpress.com/item/1005002880211697.html
Based on a basic calculation, this should allow the coil's voltage go from the actual 750 Vpp to about 1,25 KVpp. The problem is the shipment will be slow, they estimate it will be here in 29 March.
But that's not a problem, in the meanwhile there is still more to explore about the current configuration.
Fighter posted this 03 February 2024
A short question for you: what diodes would you recommend (or you are using) for the Avramenko plug ?
Hopefully I have them in my stock. Else I will need to order some from the store.
Maybe you posted the information in our site but I didn't found it, sorry about that.
Jagau posted this 03 February 2024
Hi Fighter
For my experiments I use 1 ampere 1000 volt UF4007 fast diodes
If you go to very high frequencies, like in Doc Stiffler's experiments, it is better to use high frequency diodes 1n914 or 1n4148
Fighter posted this 05 February 2024
No very high frequencies, just tens of KHz, but high voltages. When the new voltage booster will arrive I estimate I will reach 1.25 KVpp. Not sure if my estimation is correct and if UF4007 will handle that but I'll see and I'll give it a try at that point.
For now, with the actual ~750 Vpp, UF4007 is perfect.
Thanks for the advices !
