  • 5K Views
  • Last Post 22 November 2023
Jagau posted this 05 March 2023
Congratulation fighter
This circuit will work non-stop as long as it is in energy reception mode, the sea of energy that surrounds us. Play with it, a circuit that everyone should try and understand how it works, you can make several and they will all go on forever.
For the good news yes there is and it will be said here.
Well done again
Fighter posted this 06 March 2023
Thank you Jagau.
Yes it's a very nice eternal device which make us aware about the sea of energy around us. And I'm not talking only about the radio spectrum, this device is clearly using the energy coming from space (stars radiation, neutrinos, everything). I'm saying this because I saw how the pulses go faster when I just put my hand closer to the device without even touching the circuitry.
I'm sure this device will work even in a place where is no man-made/artificial radio spectrum. Maybe the pulses will be slower but it will still work.
I intend to build a few more, miniaturized versions. Because this one is on a testing board and last evening I also found that beside the wrong resistors there was also an imperfect contact on one of the pins of the big capacitor, sometimes it didn't worked when that capacitor was moved a bit. It happens on these testing boards sometimes...
Jagau posted this 06 March 2023
You are going to have a lot of fun with this very simple little circuit, it makes us smile.
For the good news, doc Stiffler also made one but it lights up 4 LEDs continuously without batteries, I'll tell you about it.
I have studied very deeply what he has done and I find it amazing what he has shared for free without anyone continuing it, I will only share this publicly here on the public thread what I have found to date.
I will surely do. I'm already thinking of what Don Smith once said (quoting from memory): "the grounding can be made in ground or in air". I'll look in the videos when he said that, maybe there is more information about grounding in air. If that can be accomplished then this little device will not need a wire to the ground anymore.
This is another video made in daylight, it shows how strong the luminosity is:
Thank you for sharing this device !
Shadow_ posted this 06 March 2023
Thanks Jagau and Fighter for sharing✌
I will be installing electronics on Friday - I ordered parts
Quoting:Gandalf
The thanks go to Jagau, I just replicated it.
Very nice, we will assist you in building your own replication 🙂
Make sure you have a grounding connection available in your home's electrical wiring.
🙂 thanks for the grounding advice; I will probably record a video outdoors; I have a place for it in the countryside
till Friday ✌
Gandalf
Jagau posted this 07 March 2023
Outside the house you should have good voltage, it's a good idea to try Gandalf.
Fighter posted this 08 March 2023
With Jagau's approval I'm going public with my replication.
AlteredUnity posted this 09 March 2023
Was able to throw this together pretty fast, and worked somewhat, blinks about every 2 seconds not quite as bright, though didnt have all the right parts. Have too order that polyester capacitor and a few other peices to do it right, then ill cut my leads down to make it a little prettier. Right now in place of the 10uF i have a 4.7uF and as i go lower the frequency of flashes gets higher but lumosity decreases which is a bit self explanitory.
The Red is connected to my workbench, the grounds is coming from my powersupply.
Thanks fighter for the layout, it made the assembly so much quicker. Jagau, you are a smart man, part of this layout reminds me of your SRO. By any chance are you able to describe the operation of maybe this circuit,  but your SRO circuit?
I also noticed i can put two of the LEDs in parallel, and the lumosity of the first doesn't diminish, the other lights just as well:
Thanks for sharing!
