  • 19K Views
  • Last Post 2 weeks ago
andy2 posted this 04 November 2023
Hello Inception
Another great document to read is this one by David S. Alexander MSE Technology Applications
wrote for NASA
It is insteresting that this topic is the subject of their interest.
Fighter posted this 06 November 2023
I was searching in my components stock and seems I don't have any functional IRF3205ZPBF MOSFETs left.
I found two but they show signs of heat, probably burned during the ZPM development.
But I still have two IRFP250 which seems to be brand new so I'm gonna use one of them.
I'm updating the schema accordingly, I'm adding the resistor on MOSFET as recommended by Jagau and also I'm adding some reference info about IRFP250 (more like just some notes to myself):
About the electrolytic capacitor on voltage booster's output, for now I'll try to go without it as I want to keep the advantage of the adjustable voltage from the voltage booster.
Also I was looking for this connector which came with my signal generator, finally found it in some old boxes so I don't need to build one. The similar connector I use with ZPM is going directly in my MOSFET driver (the black box) and is soldered inside so I don't want to dismantle that one.
Jagau posted this 14 November 2023
Hi, Joel Lagacé is once again surpassed,
He explains the DonSmith effect in his own way, read his very interesting pdf,
 http://typeright.social/forum/showthread.php?tid=267
He is very involved and his YTs are excellent and he has also built an even more interesting M.F.T., magnetic flux triode. Look like a beyond unity device.
Fighter posted this 14 November 2023
Yes, I saw his video a few times these evenings after I finished my work hours.
He is using a sligthly different approach than Don Smith, he have a electrical one-wire contact between input and output.
On the left side is Don Smith's method with capacitors perpendicular on primary coil's flux, on the right side is Joel's method:
I'm attaching Joel's document to this post.
Also the video contains the answer to Shelfordella who said here about radio stations
You can't receive more than is transmitted
implying that radio receivers are actually consuming a radio station's power if they are too many which is actually not true:
I told him the same thing in my answer here:
The truth is, as Don Smith taught us, not a single electron is transferred from the radio antenna to the antennas of the radio receivers.
If you place 10,000 radio receptors around a radio station the input power consumption of the station will not increase even with a single miliwatt.
What the antenna of a radio station is doing is to create ripples in the aether / zero-point / quantum field, however you want to call it. The only reason for the need to increase the power of a radio station is not to accomodate with more radio receivers but to extend its range/radius, to create bigger ripples so it can be received at bigger distance.
What the antenna of a radio receiver does is to "feel" those ripples and replicate the same waveform but it does that without consuming even a single electron from the power station's antenna.
Don Smith's coils are actually antennas:
Each set makes an exact copy of the full force and effect of the energy present in the magnetic waves. The originating source is not depleted of degraded as is common in conventional transformers.
Shelfordella posted this 14 November 2023
loaded dipole antennas in a coil.
Fighter posted this 20 November 2023
Just an update, this night I worked on building the switching circuitry as in the schematics presented in one of my previous posts above.
As it's almost 5:30 AM here I don't have time anymore to present the details.
I'll take more photos today maybe in the evening and I'll show more details and add notes on those photos.
Will try to find time to start testing the device: the high-frequency switching behavior, coils natural resonant frequencies (they should be the identical or very close).
Still pending: fixing the variable capacitors on the mobile supports, connecting wires to them and finding a solution to be able to rotate their axis from outside when they are inside the coils.
I'll try to move faster with this project even if it's very difficult to find time for working on it.
Fighter posted this 21 November 2023
As I promised, I'm adding more details.
Use the Image Magnifier for checking the details in the images.
This is the schematics with annotations:
And this is the photo with the same annotations for helping in identifying certain points of the device:
And here another two photos of the device from the left and right sides:
As you can see the MOSFET and the resistor can be replaced in a few minutes if they're damaged.
I know, you may say it's too much trouble building it this way but as I said I want this device to be modular with easily interchangeable parts for diverse configurations and experiments with Don Smith's tech.
I'll come with updates, trying to find more time to move faster with this project.
Jagau posted this 21 November 2023
Hello Fighter
Jus t for my information
Do you have a third movable coil inside the two outer coils like D,Smith done?
Maybe it will come later ?
No, the first experiments will have variable capacitors with their plates perpendicular on the magnetic field of the big coil (the two identical coils are actually forming a big coil with a gap in middle, the two coils are not opposing).
For testing this:
allows magnetic waves to change back into useful electrical (coulombs) energy. Magnetic waves passing through the capacitor plates do not degrade and the full impact of the available energy is accessed. One, or as many sets of capacitor plates as is desired, may be used. Each set makes an exact copy of the full force and effect of the energy present in the magnetic waves. The originating source is not depleted of degraded as is common in conventional transformers.
And those variable capacitors will be placed on mobile supports which can move inside the coil. See the mobile piece inside the tube in the image below:
 But there will be diverse experiments and at some point I can experiment that configuration with other mobile coils inside theese coils. The device is modular with easily interchangeable parts and it can be adapted for many kinds of configurations and experiments.
Fighter posted this 22 November 2023
I just want to add here the explanation of this researcher about the same Don Smith Effect with a coil and many capacitors placed near that coil where we can get energy without increasing the input.
This guy is speaking the same language like us when he's talking about the zero-point field.
The explanation starts at the beginning and ends at 04:40:
The important point is the energy on the output is obtained between those (theoretically unlimited number of) capacitors and the ground.
I don't intend to use high-voltage so hopefully the Don Smith Effect can be reproduced with low-voltage too, like the 30V I have available with my device.
I will start working with high-voltage only if there is no other way to obtain the effect.
