  • 40K Views
  • Last Post 2 days ago
Fighter posted this 24 December 2023
I guess high voltage is the must (at least few KV) but I am not sure yet.
Thanks. Well, I'll find out. I have about 730 Vpp in my device, I'll see if I could reproduce the effects of Don Smith's tech with this. If not I could build new coils with more turns, that will make the device go to KV ranges.
High Voltage Oscilloscope Probe Design
How to build a 1000 to 1 HV oscilloscope probe DIY
Maybe this could help
Thanks Jagau !
Fighter posted this 26 December 2023
Some updates, I just finished the two extraction modules.
The first prototype was a failure because I didn't had enough precision and the space inside the variable capacitors holders is very small. When I've built it I saw that when rotatiing the variable capacitor's knob the plates getting out of it were blocked by the edge of its holder (indicated by the red arrow):
After this failure with the first prototype I needed to increase the precision because every milimeter is important in drilling the holes in the plastic support so the holes match exactly the holes in the variable capacitor's body while the plates getting outside of it don't touch the support's edge.
But finally I found a method for increased precision and I've succeeded.
Here are the details of one of them:
And here are their variable capacitance ranges.
For the first extraction module we have a capacitance range between 0.04 and 0.61 nF (40-610 pF):
And for the second extraction module we have a capacitance range between 0.09 and 0.65 nF (90-650 pF):
And here is how these modules look like mounted inside the coil (they can slide deep inside the coil):
It's time to start the initial tests to verify the Don Smith Effect, more specific this one:
allows magnetic waves to change back into useful electrical (coulombs) energy. Magnetic waves passing through the capacitor plates do not degrade and the full impact of the available energy is accessed. One, or as many sets of capacitor plates as is desired, may be used. Each set makes an exact copy of the full force and effect of the energy present in the magnetic waves. The originating source is not depleted of degraded as is common in conventional transformers.
I'll try to find time to do it and I'll come with updates.
Most probably I'll need to record videos of the experiments 'cause there would be too much information to present it just with images.
One correction: last night I mistyped the capacitance ranges in the previous post, obviously we have ranges under 1 nF.
I corrected them.
Atti posted this 27 December 2023
Fighter.
Thank you for sharing your work.
Fighter posted this 27 December 2023
You're welcome, Atti.
That's why we are here - for exchanging ideas, data, experiments and results on our way to our common goal. By doing this we all are advancing faster than each other working on his own, advancing on our road to Rome. šŸ™‚
Jagau posted this 30 December 2023
Talking just about position of primaty and secondary coils, there are two ways to reproduce the Don Smith effect
The one that works
and the other way that I never managed to make work
Shelfordella posted this 11 January 2024
Hi Jagau, where are those screencaps from? They don't look like they come from Don. thanks.
Jagau posted this 11 January 2024
 This is a screen copy of the book that Rich Friedrich did on Don Smith patent.
Ok, thanks. i also found this https://weareinfiniteenergy.wordpress.com/the-don-smith-magnetic-energy-crafting-systematic-index/
Jagau posted this 12 January 2024
Yes this is the book I'm talking about
