  • 7.6K Views
  • Last Post 2 days ago
UndisclosedMember posted this 08 January 2020
Your ZPM is extremely important and the entire reason I showed the Experiments I did. Your work is critical in moving forward!
I urge all Members replicate your ZPM!
So please, I urge you to continue your work! And, as you say, a replication may help also!
Yes exactly, they use the same principles! Exactly the same! Just a different way to get to the same ball park!
Soon, a new geometry will come and it wont make sense, especially after these experiments. I have said we can have problems with the Machine choking off the Magnetic Fields, but there is a way around this. So for this reason we need to keep open minds.
The thread: Some Coils Buck and some Coils DONT gave a lot of information, the problem is, because the figures were poor, no one paid any attention. However, massive amounts of information can be gained from this thread. Information that the average EE will say is wrong, but, I have experiments to prove this is true...
I agree, keep your ZPM intact, its an important machine!
It takes time for understanding to be achieved, I have had to repeat myself many times, but people are starting to get it... Its thanks to your machine and others like Graham Gunderson and even Tinman and his RT which was very important for the momentum of what we are doing.
People look for proof, they see scam... Its sad, and its so extremely obvious! With just a little understanding, people can build these machines for a few dollars and an hours work!
Isn't that just crazy!
I would like to quote:
On that “blessed day” when we arrived and witnessed the VTA Device in operation it is a day I shall never forget. To actually see a Device that only would cost approximately $200 dollars and create all the clean energy you would ever need was “awesome”. I know I have been “altered” ever since knowing that such a Device existed.
Ref: ATTACHMENT floyd sweet.pdf - Maurice Campbell Documents.
You can see, Maurice commented on the Cost in the above quote! How cheap it was!
We will see a day, where angry people, angry for being ripped off for so long, will storm the streets! We will never again allow Government govern us! We will never again allow Bankers to be in control of Banks!
The establishment is doomed! They have bought down a mountain of rubble on themselves!
Names of Humanity's Traitors will be published! Some will be punished for their crimes! Many will take their own lives for the guilt they incur on themselves!
I say, isn't it easier to just be Good! Good always wins, eventually!
Jagau posted this 19 January 2020
Hello Fighter
I have tried several configurations with different number of laps without obtaining good results.
I even tried a configuration with 3 coils as in the photo and there I have a better result but not even like you.
I do not give up and will come back later with others try.
Maybe I misunderstood your configuration?
In the meantime I hope your move went well and also say did you do any other tests?
UndisclosedMember posted this 19 January 2020
@Jagau,
If I may, would you mind sharing more information? Turns, Wire Gauge, Frequency, Output Voltage under Load, Load resistance, Circuit, and other info you think might be relevant?
We know from Experiment and the Math, the Length of the Coil can also play a role: B = μ0N/LI
Where:
B = the Magnetic Field in Tesla.
μ0 = the magnetic constant.
N = the Number of turns.
L = the Length of the Solenoid.
I = the Current.
It is important that sufficient B Field does sufficient work to produce the required effects. If B is not sufficient, or the Actions of each B Field is not sufficiently interactions, then results will be poor.
I hope this helps some!
Jagau posted this 20 January 2020
Yes indeed UndisclosedMember,
Ok I tried with 20 gauge wire with coils of 200 and 100 turns each in partnership mode and also in additive mode with different voltages of 9, 12, and 24 volts, and a 12 volts bulb lamp, nothing wanted to do. Working frequency was 325khz, But I know that the metglass core is optimized for a max of 100 kHz.
I would have a theory however.
As the Metglass is a material of high permeability and that it surely has, as Don Smith said, the characteristic of a piezoelectric material. So I think Fighter found exactly the right length of wire and the number of turns it takes to trigger this piezoelectric effect.
  The Metglass becomes at a precise frequency a feedback transformer which provides more energy than it consumes.
I am currently testing this theory through various experiments.
Fighter posted this 20 January 2020
I didn't do additional tests, I just returned from the holidays break. Within 4-5 days I'll have enough funds (this entire moving thing was extremely expensive) to buy a second AMCC-200 so I can begin replication of a second ZPM and experiment with different coils configurations without dismantling the prototype.
Can you post the waveform you have on your ZPM's output ? Is the specific ZPM pattern present there ?
Did you do the frequency sweep to find the optimal frequency for your configuration ? Also, just for double-checking, use a compass to confirm the polarity of the magnetic field for each coil just to make sure the magnetic fields are opposing.
What duty-cycle did you tried ? The optimal frequency range change if duty-cycle is changed.
If possible could you post a video of the frequency-sweep procedure for your ZPM ?
About frequency, 100KHz is not the maximum for Metglas, I remember I was going near 700-800KHz in the initial tests and I still had a 12V/5W light bulb lighting. Right now with the 12V/55W light bulb I'm playing within 90-160KHz range. Remember the optimal frequency changes dramatically when load is changed or duty-cycle is changed, with a 12V/5W light bulb it can go near 700-800KHz but with a 12V/55W light bulb 160KHz is the upper limit. Also what I found since the beginning is that going below 80-90KHz dramatically decreases ZPM's performance, it's starting to get more and more power from the DC source (at least what the DC source's display is showing, I know that's not a precise reading).
About voltage, I always used 25V for ZPM, I tried going much below 25V (like 18V, 15V, 12V) but the results were poor. So if you have 24V stay with that voltage, if possible go to 25V (I don't know if you're using a variable or fixed voltage source).
About the exact length of wire, I doubt I found it from the first try, I'm not even sure about the exact number of turns, they are 150/300 ratio with error rate of +/- 10 turns for each coil. Also, I'm not sure if the positions of the coils on the core matters, probably not.
I'll try to assist as much as possible.
Thank you very much for all this information.
Glad you were able to relocate to experiment, yes the moving and the time of the holidays, are expensive.
Ok one thing that I had not noticed the ratio is coils is 1: 2 is that right?
With this new setup I will redo tests, I used 1: 1 already there is a good difference.
OK thank you
You're welcome. Yes, 1:2. Try with 150/300 turns ratio.
Fighter posted this 21 January 2020
@Jagau, a question, can't tell because the photo is too small but is the wire you use multifilar ? 'Cause I don't use multifilar, I use solid copper wire, that could make a difference, I don't know.
Jagau posted this 21 January 2020
Hi fighter
I use 20 gauge solid copper cable.
In the photo it is a configuration with 3 coils that I had tested.
2 coils at the top and one at the bottom.
Fighter posted this 22 January 2020
Got it, my mistake. Thanks for the clarification.
