The Don Smith Effect
  • 19K Views
  • Last Post 6 days ago
For a while I gathered information on what Don Smith called "The Don Smith Effect".
There is a Don Smith's patent number NL02000035 talking about a kind of transformer which is also not depleting the input source, just as you presented here with Dr. Stifflers's technology. The patent is in Spanish language but it can be easily translated using the machine translation:
I think that what Dr. Stiffler didn't realized is the fact that the secondary coils (the ones used to gather aether/zero-point energy energy) are actually used as capacitors (remember a coil is in the same time a resistor and a capacitor).
If I am right we are talking about the same phenomenon/effect and this can unify the technologies of Dr. Stiffler and the technologies of Don Smith.
What the patent says is: if you have a coil running at its resonant frequency and you put some plates at right angle outside the coil so the plates create a capacitor, the plates will gather energy without affecting/depleting the energy of the input source. It's the same thing you presented in your experiments using Dr. Stiffler's technology. From my research on this I think (I'm not sure if it's required) that the plates should be able to move closer or away from each other so they can form what we call a variable capacitor in order to be able to tune the device and get more efficient in gathering the aether/zero-point
But basically this is what Don Smith is talking about in its patent:
It is found that creating a dipole and inserting capacitor plates at right angles to the current flow,
allows magnetic waves to change back into useful electrical (coulombs) energy. Magnetic waves passing through the capacitor plates do not degrade and the full impact of the available energy is accessed. One, or as many sets of capacitor plates as is desired, may be used. Each set makes an exact copy of the full force and effect of the energy present in the magnetic waves. The originating source is not depleted or degraded as is common in conventional transformers.
Don Smith's discovery is what he calls a "Don Smith effect", where the charge if put on one plate of the capacitor, it duplicates the same charge on the second plate from the ambient background (air and earth groundings). This forms an open system, where the input never gets depleted. Capacitor used determines the power output as he mentions. This is different from the conventional closed circuits where the source is grounded back to itself (in other words, sees"-" directly, the source is self-destroying).
A few images from the patent:
And here are two images I found showing the configuration from Fig. 3 (the image above):
I'll organize my material and my notes related to the Don Smith Effect and when I'll find some time I'll continue in this thread.
I have a few variable capacitors here which I bought from Thailand some time ago:
I don't know if I can use them in a Don Smith Effect experiment (Don Smith talks about plates changing distances to each other which is not how the modern variable capacitors work), but I intend to give it a try and create an experiment about the Don Smith Effect.
Seems the only way to gather aether/zero-point energy and to not affect/deplete the input source is to not have the source grounded back to itself (in other words, to not see the "-" directly, so the source is not self-destroying).
It's exactly what another of our teachers, Tom Bearden, told us: "Don't destroy the dipole !".
Because that's exactly what our official tech using symmetrical and closed systems is doing. That's why it will never be able to become overunity.
Jagau, I know I said I intend to replicate your device(s) from your experiment here related to Dr. Stiffler's tech but just replicating your work is not very helpful, maybe a better way is to work in parallel on a Don Smith Effect experiment and if I am right maybe we can unify the technologies these two great teachers demonstrated to us.
Jagau posted this 30 May 2023
A Don Smith tribute in pdf
“Energy cannot be created or destroyed, energy can only be transformed or converted”
Fighter posted this 31 May 2023
Thank you Jagau !
I'm gonna read it carefully.
Fighter posted this 07 July 2023
I'm making this thread public as (after some delay) I'll start building the device required for this experiment.
Shelfordella posted this 08 July 2023
This is gonna be interesting. I read Don's book for a while but it is very poorly written especially if one doesn't know what to be attentive for, I think he's trying to show the basic 4 principles by multiple experiments, the non-diverged Heaviside flow (by the tube experiment, maybe it's the same effect as 'EV Gray', maybe this is the energy source for the receiving coils close to the transmitting/antenna coil, for which he used the piano string analogy), magnetic resonance (by the 2 coils on a stick sonar oscillator), how flux and capacitance/inductance distributes by the location of the primary coil on a Tesla coil and how to combine them in phase from 2 segments of the 2ndary, and the effects of motional inductance on spin and direction of two types of current by E and B, but it's still too vague for me.
Fighter posted this 08 July 2023
If I am right this will unify Don Smith's tech with Dr. Stiffler's tech shown by Jagau in his SEC experiments.
What I want to try first is to use these variable capacitors inside the coil.
I know, not an external variable capacitor like he shows in his experiment and drawings.
I have two reasons to do that.
First: my assumption is inside the coil the magnetic fields should be more powerful and the effect should be more powerful.
Second: it's more difficult to build an capacitor that big and fix it outside of the coil and still keep it adjustable/variable.
So I'll try first with what I already have and see how it works.
If it's not working this way I'll need to find a way to build that customized external (and most important - still variable) capacitor.
This recent video of Master Ivo has too much resemblance to Don's Tesla POC, maybe it contains an idea or two for your experiment:
Yep, we have it in a dedicated thread here.
These coils are identical but they are not working as POC, Master Ivo is using them as asymmetric coils (like ZPM's coils) by putting in parallel with them different capacitors. There are more details in the dedicated thread.
I never used pancake coils but if it will be necessary I will familiarize myself with them.
There is a lot on Master Ivo's channel about this kind of coils.
Fighter posted this 18 July 2023
Last weekend I found some time to start work on building this experimental device.
I can't use 3D printing for this (too time consuming and probably expensive to design and print) so I need to use objects already available and adapt them.
I have about 10-15 identical plastic bottles I gathered for this and I can use them for building a modular device with interchangable parts.
There was some work to do (and a lot of mess):
This is how I designed it in my mind before starting to build it:
The caps in the middle will be fixed to each other and they will keep together the coils supports (the transparent tubes).
The coil supports are detachable (can be unscrewed) so I can easily wind the wire on them and then attach them back.
I can build more of these with different types of coils (single wire, bifilar etc.) as I need them without needing to unwind a coil and then wind a different type of coil again and again.
For example if at some point I want to have opposing coils I'll just unscrew the coil support on the right side and mount back another coil support having a coil opposing to the coil on the left side.
Why would I want that configuration ? Well, because as I said this should be a modular multi-purpose experimental device and at some point I intend to test this (as it appears in Don Smith's book) with a ground connection:
We need to test all the posibilities from what Don Smith told us.
Now back to the description of the device...
The variable capacitor supports are cut in a way that they are able to enter inside the transparent coil supports and they can slide inside so the variable capacitor can be placed at different depths inside the coils.
This is necessary for placing the variable capacitors in different zones inside the coils to see if there are any differences in the energy collected.
For now I need to find some kind of tubes to attach them on the variable capacitors trimmers so I can adjust them from outside even when they are slided deep inside the coils. I don't have those tubes yet and I need to find where I can find something like that or how to build them.
Also I checked and I don't have matching screws for the holes of the variable capacitors so I can fix them on their sliding supports. I'll search for that kind of screws. The screws lengths are important too, they shouldn't be so long else they will touch the variable capacitor's blades inside.
I still have work to do until the device is ready, I'll continue as I find time and I'll post updates here.
Fighter posted this 18 August 2023
Unfortunately this project is advancing slowly because I didn't found enough time to work on it.
Now I'm preparing to leave Bucharest until the begining of September so I'll not be able to work on it but I used the time I had until I live to advance as much as possible.
The device is starting to look like I designed it in my mind.
I'm adding some photos and details.
I assembled the piece which will keep together the coil supports:
Sorry for the mess...
I added inside the device a power jack, a switch and soldered the wires to them:
I soldered two connectors to a board placed inside the device, will be useful for connecting the power wires to the coils and will have an extra slot for free for each connector. The 3 slots on the left side are connected together and the other 3 slots on the right side are connected together.
In the image above you may notice a red wire having a fast diode, that wire is the positive coming from a 30V (that's adjustable) DC-DC voltage booster. The diode is there to stop the BEMF from coils to reach the output of the voltage booster.
On the top of the piece which keeps together the coil supports (the transparent tubes) I placed another connector which will be useful for connecting together the left coil with the right coil. Or halves of coil, depends on the experiment's configuration, that's why I've built the device modular with changeable coils - to be used in diverse experiments/configurations specific to Don Smith's technologies.
In the next photo you may see some details inside of the device (the electric circuitry).
And this is the current status of the device's construction.
The device will be powered by a rechargeable 9V battery.
Between the battery and the device I will use a digital DC power meter like this to observe the input power.
The voltage booster will rise the voltage to 30V (that's adjustable).
On the output of the voltage booster, on the negative I will place a MOSFET which will be driven by my replica of Jagau's Square Wave Oscillator or sometimes maybe by my signal generator.
I'll continue to work on the device when I'll return, I still need to mount the variable capacitors on their sliding supports.
After that I'll need to build the coils and then finally start the experiments.
I'll keep posting updates here.
