  • 3.6K Views
UndisclosedMember posted this 25 September 2019
Fighter is right!
One can theorise all day long and get nothing!
One can Simulate all day long and get nothing - Most likely as sim's don't have enough data on this tech!
Experiment is the ONLY way forward!
SL, no more on Theory and Simulation please, we already know how it works we already have the answers, we don't want to know anything more about stuff that's not relevant.
Atti posted this 25 September 2019
Hey Figher.
I'm probably not saying it right.
But be aware of similarities. Any overheating of the FET switch may be (?) Caused by the actual excess.
So it is not a matter of looking for electricity and voltage, but for heat energy.
That's what Robert Adams talked about at the engine he developed.
Or the result from Leslie I. Szabó's EBM C720.
Here, too, it gives off the heat in heat. It has been documented in great detail and in Kw.
But I'm probably wrong. Just keep in mind.
like this one here
http://www.mareasistemi.com/ARCHIVIO/RIVISTA%205%20MareaSistemi%202010.pdf
OK fellows - we get it - sorry!
SL
Hey Atti,
Agreed, you're right:
Components that Heat means the dissipation of electrical emergy, often a component at the maximum rated efficiency for a given voltage.  Excessive Current heating the element, as we would heat a Heater.
Lets not forget, an Electrical "Generator" also heats, and also is rated at a specific Voltage and Current.
This heat lost, is Energy, Energy burned, a Loss of Energy that must be accounted for.
We have covered Mosfet switching here: On and Off, Conduction in a Mosfet I am sure Fighter has read this thread and don ehis homework on the Switching of a Mosfet.
Maybe the only think I would like to add is an extra protection diode:
Where D1 might be an Ultra Fast Hv Hc Diode.
This may help in the heating of the Mosfet.
SL
Hey SL,
I see you're just trying to help. Thank you for that!
Who are your group? Who are you trying to help? We have many questions!
@All Readers,
I urge you, when you achieve results, don't be sucked in by the cartels:
Well, an interesting day, today I had a Skype Friend request from STEHO Energy...
I thought, after my long research that they had gone belly up. Perhaps not:
Like I told Stefan, I have no intentions of becoming friends with the Energy Cartel like others in the field are! I see only problems with a relationship, a conflict of interest if you like. I do not wish to be un-friendly or rude, so if STEHO reads this message, I hope they understand this.
Ref: Steho Energy Friend Request
This is not the first time I have been approached, there are many of them, many different names, all tasked with the same goal: "legally wrap the inventor up so tight they need permission for another breath"!
Don't become another statistic like so many have before!
Best to keep real success stories to yourself and help/teach others how they can get there also.
EXACTLY like you and some others here are are doing right now.
Knowledge is the ultimate key. Not the results.
Fighter posted this 25 September 2019
@UndisclosedMember, in my opinion we will not be able to get any results if we're thinking only in the old way, what we've been told in schools. We can't build different/revolutionary machines and can't get different results following the same way and following the same standard "recommendations". That way of thinking, those standard paths and methods, those "recommendations" got us in the situation we're in today: burning everything on our planet in order to get some energy (just like we did 100 years ago) but now we're actually in process of destroying our planet and ourselves.
Look at this man, he was the best inventor of all times, while other physicists told us and still tell us in their theories that a over-unity machine is impossible he actually made over-unity machines. Does he look concerned about "parasitic" in all those spikes surrounding him ? Does he look concerned about if his switching methods have ringings or if the switching is perfect ?
Let me tell you something, unfortunately this man was too much ahead of his times. He had no oscilloscopes, his "MOSFETs" were big capacitors discharging in spikes produced by a rotating device, as that device was rotating faster then more spikes/discharges it produced, that's how he controlled the frequency of his "MOSFETs". Do you think his switching was perfect and without ringings ? Probably it was full of ringings and "parasitic" as we call them today.
What they tell us in schools is that we should eliminate all those "ringings" and "parasitic" in order to have our machines working "better". What they don't understand or don't want to tell us is those "ringings" and "parasitic" are actually the way our machine is interacting with the zero-point/ether (or however we want to call it) field and the only way our machine can be an open system capable of gathering energy from that field instead of being a closed under-unity system. I'm talking about interaction like this (red arrow):
Try to simulate ZPM in any simulation software, you have all the details here, because of the "restrictions" (limited formulas) included in that software you'll see the simulation will tell you this device is wasting the entire energy provided by the DC source in a useless fight between two opposing magnetic fields. The simulation will tell you that because of those opposing magnetic fields the coils of the ZPM should overheat and there would be not enough remaining energy to additionally power up a light-bulb on its load. You will not see in that simulation what I'm actually presenting here, the actual behavior and let me tell you the coils of ZPM are always cold, never noticed them becoming at least a bit warmer.
That's why we should start thinking out-of-the-box, forget their "recommendations" and what they tell us and actually experiment and see the real behavior and results of this kind of devices with our own eyes. Theory is good but only to a certain point where what theory tell us don't match with what we see in our benchmarks, in our experiments.
P.S.: I'm still curious who are those "we", you didn't answered to that question.
@UndisclosedMember, no worries, the days when they were capable of "legally wrap the inventor up so tight they need permission for another breath" are over. I'm aware of what happened to others and to their inventions. I'm not doing this for money so that would be a real problem for them and for their methods. And they know it's pointless to even try because they should "wrap" not only me but also everyone else who did read all the data I posted here and saw ZPM running. That would be practically impossible šŸ™‚
And it's not only about ZPM, we have researchers here working on different devices and showing to everyone that the "impossible" is actually possible.
So my message for them and their methods is: "not today, not tomorrow, not anytime soon. it's over so hit the road, Jack !".
About the diode protecting the MOSFETs, I also had a discussion with Cd_Sharp about this and will be done, I already bought a set of high-voltage super-fast diodes - SF28G and I'll take care of this when I'll have time, it's on my to-do list.
@Atti
Hey Figher.
like this one here
I agree with you, I don't think you're wrong, that's actually excess energy which is being lost, at some point I will need to find a way to take care of it and to put that energy in use on output. My hypothesis is that heat has nothing to do with the switching process and it's produced by ZPM sending power back to the DC source during the short time when the MOSFETs are on. In the measurements with current-sensing resistor put on input I saw evidence of currents going in both directions in that resistor, I shared the data here in an older post.
Yes, I'll keep in mind, thanks. It should be a part of this improvements stage.
